Process flow error
Process flow error
doris_c
Process flow error
doris_c
[ FlexSim 24.0.2 ]
Hi.
As shown in the picture below, the control section was created using the process flow
The control contents of the photo are as follows
It is a process structure that repeats the work of WAIT FOR EVENT (source CP26) again after confirming that two AGVs have passed since arriving at WAIT FOR EVENT (source CP26) after confirming that two AGVs have passed since arriving at WAIT FOR EVENT (source CP26).
What is wrong with the ash setting that process doesn't work?
I would appreciate it if you could explain the revised file and the explanation of the mistake I made.
thank's you
PROSESSFLOW-ERROR.fsm
moehlmann_fe
The issue is that redirecting an AGV so a CP (as final) while it is already at that CP does not finish its travel task. I'm not sure if that is a bug or intended.
But since CP26 and CP45 are travel directions in the subflows anyway, you could simplify the logic by just placing the Push to List activities into the subflow.
prosessflow-error_1.fsm
