@Pinakin K
You can do this by adding way points. A way point is created by:
Click on the AGV network path
Click on AGV network properties
Click on Way Points Tab
Add a way point using the sampler and clicking on a control point on the AGV network
Change Trigger Point to "On Arrival"
Change Trigger Requirement to "Always Fire"
Change Way Point Logic to "Wait for Defined Delay Time"
Then to make the AGV continue to the next control point:
Add "Redirect via Direct Reference" (Make sure to connect the control points with "NextLookForWork")
You can direct the AGV to continue to the next way point by adding "Redirect via Direct Reference." Make sure to add more way points for each control point in the AGV network
