How to make AGV stop at each control point for specified amount of time?
pinakin_k
Message 1 of 14
pinakin_k
[ FlexSim 18.1.2 ]
This question was asked before, but the solution did not help me.
I have a model of a closed path having 24 control points and 23 AGVs. the agv should stop at each CP for specified amount of time.
Replies (13)
Message 2 of 14
pinakin_k
Here is the model: agv-new.fsm
Message 3 of 14
isaac_l1
@Pinakin K
You can do this by adding way points. A way point is created by:
Click on the AGV network path
Click on AGV network properties
Click on Way Points Tab
Add a way point using the sampler and clicking on a control point on the AGV network
Change Trigger Point to "On Arrival"
Change Trigger Requirement to "Always Fire"
Change Way Point Logic to "Wait for Defined Delay Time"
Then to make the AGV continue to the next control point:
Add "Redirect via Direct Reference" (Make sure to connect the control points with "NextLookForWork")
You can direct the AGV to continue to the next way point by adding "Redirect via Direct Reference." Make sure to add more way points for each control point in the AGV network
Message 4 of 14
pinakin_k
I did not get it when you said, Make sure to connect the control points with "NextLookForWork"
Message 5 of 14
isaac_l1
Make an "A" connection from one control point to the next one and then select "NextLookForWork"
Message 6 of 14
isaac_l1
Here is an example model. Hopefully this is similar to what you are trying to achieve.
agv-stop-at-waypoints.fsm
Message 7 of 14
pinakin_k
agv-new-7.fsm
its giving an error saying, it could not find a valid path
Message 8 of 14
pinakin_k
Its working now, I had to shift the control points a bit further or backward where the network lines are joined together. If I put the control points on the intersection of the network lines, it shows a message that "it could not find a path to reach the next control point"
Not sure if its a bug or not.
Message 9 of 14
isaac_l1
Do your network lines need to be separated? Or can the network lines be one long line?
Message 10 of 14
pinakin_k
Some of them need to be separate. Not all. Because some would be accumulating, and some would have different speeds.
Message 11 of 14
isaac_l1
The control points have to be either on one track or the other, they cannot be where the connection is located. This is because the connection point is not actually a part of the track, so it doesn't have the logic built into it.
Message 12 of 14
pinakin_k
@Isaac Litster
But the control points snap on to the connection so even if I put a little offset on the control point, it goes and snaps to the connection of two tracks. Is there a way to do that. I turned off the snap to grid but it does not work.
Message 13 of 14
isaac_l1
Sorry for the late reply. Do you still need help with your question?
I'm not sure if I understand the situation correctly. Could you possibly draw a picture or attach an image of an example of the control points snapping?
Message 14 of 14
pinakin_k2
Hi, my previous account had some problem, so I'm replying with this account.
If you see the control point next to the connection, so If I put the coordinate of the control point offset by 1mm from the path connection point, it snaps on to the path connection point.
I tried turning off the snap to grid, but it is still not working.
