How to get the different recipes output from mixer.
Rambabu
Rambabu
[ FlexSim 23.1.3 ]
Hi flexsimers,
I have a query on mixing the ingredient in different proportions to make different recipes using mixer. In my model I am using mixer to mix four ingredients and make four different recipes. The ratio of ingredients to be mixed are taken in the global table. Is there any solution?
I am attaching the model here: mixing ingredients.fsm
Thankyou.
jason_lightfoot_adsk
Just write to the table which is found at:
Table recipetable = getvarnode(current,"recipetable");
Then read the values from the global table with your format you'll need something like:
Table recipeTable=getvarnode(Model.find("FluidMixer1"),"recipetable");
Table globRecipes=Table("RecipesTable");
string newRecipe="Recipe2";
for (int n=globRecipes.numCols;n>0;n--){
    string ingredient=globRecipes.getColHeader(n);
    int row=recipeTable.getRowByKey(ingredient,1);
    recipeTable[row]["Amount"]=globRecipes[newRecipe];
But you need to change the ingredient names to match those of the mixer. Example attached.
Note you can also choose the option to update from a global table on the triggers, but that relies on your table format matching what the trigger expects.
mixing-ingredients_jl.fsm
Rambabu
@Jason Lightfoot The above code indicates only for recipe2. Can you Explain that How to do for remaining recipes by order. I am using global table data only.
Thankyou
Create a user command that accepts two parameters: the mixer and the recipe name.
In the code place this version of the above script:
Object mixer=param(1);
string newRecipe=param(2);
Table recipeTable=getvarnode(mixer,"recipetable");
then call the command using
changeMixerRecipe(<mixerObject>,<recipename>)
where you replace the chevron parameters with a mixer object and a string name of a recipe. eg:
Object mymixer=Model.find("FluidMixer1");
string recipe=getRecipeForOrder(orderNum);   // another user command
changeMixerRecipe(mymixer,recipe);
I can't tell you how you map the order to the recipe - that will be based on the data you know and have.
Rambabu
@Jason Lightfoot Thankyou for your answer, But I applied that code to my model that shows error. When I debugging the code. It is showing the error in the last line. Could You tell me why it was going wrong.
  1. Table recipeTable=getvarnode(Model.find("FluidMixer1"),"recipetable");
  2. Table globRecipes=Table("RecipesTable");
  3. string newRecipe="Recipe2";
  4. for (int n=globRecipes.numCols;n>0;n--){
  5. string ingredient=globRecipes.getColHeader(n);
  6. int row=recipeTable.getRowByKey(ingredient,1);
  7. recipeTable[row]["Amount"]=globRecipes[newRecipe][n];
  8. }
Thankyou
I don't think the error screen matches the code - nowhere do you mention Recipe3 - we'd need to see the model to determine what is wrong. Your row headers should look something like this:
