How to find a flowitem using its unique id?
suhas_h2
suhas_h2
[ FlexSim 19.1.2 ]
Is it possible to find a flowitem using its unique id?
zac_h_adsk
@Suhas H2
Are you able to post your model? If so we can better help you with your problem in specific.
There are 2 ways you might be able to do this. First, at the top of the screen click on View -> Find Objects and then on the right side of your screen you will see a location to place a value and click Find. Depending on your situation you might be able to click on the label or id and the search for a red outlined box which you can click on and it will highlight the item in the model.
suhas_h2
Thanks for the reply @zachary.h
I tried accessing a flowitem using Model.find(tostring(uniqueid of item)) this didnot work for me.
Do you have any other command to access flowitem using its unique id?
zac_h_adsk
Can you upload your model?
suhas_h2
I was trying to use unique id to reference an object in my model.This is the practice model where i am trying to send an item from processoe to the queue using flowitems unique id.
test-uniqueid.fsm.
zac_h_adsk
The following code is all that you need to send an item.
param(1) already attaches the unique id to "item"
Object current = ownerobject(c);
Object item = param(1);
moveobject(item,Model.find("Queue11"));
