How to prevent overflow in downstream queue by using flexcript to create TS
bing_syuan_l
bing_syuan_l
[ FlexSim 18.2.3 ]
tasksequence-problem.fsmHi everyone
In the beginning, I don't want to transfer the pallet to the downstream queue upon the empty arrived.
The pallet should be moved to the downstream queue by operator after the box be placed on.
therefore, I creat a Tasksequence to operator by flexscript after robot has finished the transport.
But the downstream queue's max content is 1, It's will be overflowed.
Is there a idea to avoid this condition happend?
Thank you
tanner_p
This condition can be avoided using normal Process Flow activities (rather than custom code). The insertion of a Decide activity after the Load activity can check the contents of the queue that will receive the item and if there is not space for the item, the item will not be unloaded. Otherwise, there's not a clear-cut way to abruptly change the task sequence created through Custom Code, as it becomes more convoluted.
I've updated your model to include an example of the logic I've described. Hopefully this helps.
ts-problem-help.fsm
