How to choose random output port
SRmariog09
SRmariog09
[ FlexSim 24.2.0 ]
Depending on the case i'd like to choose a random port between 2 numbers. But it is not working, it always choose the same port.
/**Custom Code*/
Object item = param(1);
Object current = ownerobject(c);
/***popup:ValuesByCase:valuestr=Port*/
/**Port By Case*/
Variant value = /***tag:ValueFunc*//**/item.persona/**/;
/***tagex:data*/
if (value == /**/1/**/) {
return /**/1/**/;
if (value == /**/2/**/) {
return /**/1/**/;
if (value == /**/3/**/) {
return /**/duniform(2,4)/**/;
if (value == /**/4/**/) {
return /**/duniform(5,6)/**/;
if (value == /**/5/**/) {
return /**/7/**/;
return /***tag:default*//**/1/**/;
What is wrong?
moehlmann_fe
The code is correct. Does the "persona" label actually exist on the item and are its values in the expected range? If not the code would default to sending all items through port 1.
It would be easier to help, if you could upload a model.
SRmariog09
Yes it is, the rest of the cases works good. The problem is that when I reset and start de simulation, the cases with the random port go to the same port always
joerg_vogel_HsH
In an express license is randomness deactivated. Only licensed version uses randomness. You can tell then the system to deactivate randomness. Function is called repeat random streams in statistic menu.
SRmariog09
Thank you so much, I can´t believe it was as simple as that
