Version 2023 Error
Version 2023 Error
jun_j2
Version 2023 Error
jun_j2
[ FlexSim 23.0.0 ]
My model runs smoothly in version 2022, but encounters numerous errors when executed in version 2023. Could you provide some insight on this? Thanks!
time: 0.000000 exception: Exception caught in TreeNode::callMemberFunction() main function. Throwing...
time: 0.000000 exception: Exception caught in evaluation of MAIN:/project/exec/commandlist/distancetotravel/node
time: 0.000000 exception: Exception Caught in distancetotravel(treenode traveler, treenode destination)
time: 0.000000 exception: Exception Caught in ObjectFunction93__project_exec_commandlist_distancetotravel_node object: MAIN:/project/exec/commandlist/distancetotravel/node i: MAIN:/project/exec/commandlist/distancetotravel/node class: MAIN:/project/exec/commandlist/distancetotravel/node
Ben_WilsonADSK
Hi @Jun J2,
It's hard to know how to help without looking at your model. To receive a more accurate solution, please post your model or a sample model that demonstrates your question.
If your model contains sensitive information, you could first toggle your post as private using the "make private" option under your question's "gear" menu. Private questions are visible only to site moderators. You can also contact your local FlexSim distributor for phone or email help.
jun_j2
Thank you, Ben! I will post a private one as you suggested.
DanielBV
I have the same issue with my model updated to version 2024. Is it any solution for this problem?
