How to call the user command having array as a parameter?
rajankur6494
Message 1 of 11
rajankur6494
[ FlexSim 23.2.1 ]
Hi Team,
I have created a user command and passing array as a parameter. But, it is showing errors while calling the user command.
Could you help me to know where it is going wrong?
Thank you!
Replies (10)
Message 2 of 11
jason_lightfoot_adsk
Here's the documentation - you should use "var seq" in your list of parameters.
Message 3 of 11
rajankur6494
@Jason Lightfoot
Thanks for providing the documentation link.
Before, I was using Array seq = param(1); while defining user command.
Now, I made the correction as below:
var seq = param(1);
Even I am getting the same errors while calling the user command as
int Min_Time = Min_Changeover_Time([1,2,3]);
It is not accepting array as a parameter.
Do I need to change anything else?
Thank you!
Message 4 of 11
962076751
try here
Message 5 of 11
The Array type is correct in the code but not in the parameter definition of the user command where you must use 'var' or Variant.
Example attached.
UserComand_minValInArray.fsm
Message 6 of 11
rajankur6494
@Jason Lightfoot
I can't open it as it is in 2024 version.
Could you share it 2023 version?
Thank you!
Message 7 of 11
The code is this:
Array theArray=param(1);
double minval=GLOBAL_UNREACHABLE;
for (int n=theArray.length;n>0;n--)
    minval=Math.min(minval,theArray);
return minval;
The command is setup like this:
I called it using this line in a script console:
minValInArray([5,8,33])
Message 8 of 11
rajankur6494
@Jason Lightfoot
Thank you so much! It is working now.
Message 9 of 11
rajankur6494
@Jason Lightfoot
I have one more question to ask for better clarity if I can.
For return type, we have used num as the return value is an integer.
But instead of 1, I would like to add 2 return values as an output. For example:-
Final Sequence Array along with Min Changeover Time
After defining the user command, that's how I was calling it:
Here is the output:
It is not working correctly for min_Time value as it should be 224. I feel it is just taking the first element of array as output for min_Time.
Any help would be appreciated.
Thanks!
Message 10 of 11
FelixMoehlmann
Code execution stops after the first "return". You have to return the values as an array.
return [bestOrder, minTime];
Use "Variant" as the return type and assign the values as follows.
Array result = Get_Min_CO_Time(...).as(Array);
Array bestsequence = result[1];
double min_Time = result[2];
Message 11 of 11
rajankur6494
Got it @Felix Möhlmann
Working as expected. Thank you so much!
