How to add a 2nd slide and extender to Asrs
ulas_a2
Message 1 of 11
ulas_a2
How to duplicate slide and extender for asrs image
Replies (10)
Message 2 of 11
jason_lightfoot_adsk
What do you mean by "image"?
Message 3 of 11
ulas_a2
I want to duplicate the slide and extender found here.
Message 4 of 11
joerg_vogel_HsH
The slide is an object of the animation creator:
You can add objects in the animation creator and duplicate by hand the values of the existing slide object. This works under Express License, too.
If you own a licensed version you can add an object in the same level and then you switch to the tree window. You look for the drawsurrogate node in the attribute branch of the ASRS. There you copy the slide node and insert it into your created object node.
If you have already inserted a similar structure of objects in the animation creator, you can copy the attributes of the slider objects to your objects by the Tool Edit Selected Objects from the main menu View or Edit, currently I am not sure about the menu location.
Message 5 of 11
joerg_vogel_HsH
Here is an example
ASRS_2Slides.fsm
Message 6 of 11
ulas_a2
Teşekkürler Jörg.
Message 7 of 11
ulas_a2
Hi Jörg, I have one more question related to this issue. Can the added slide act like the first slide?
Message 8 of 11
joerg_vogel_HsH
If the second slider moves parallel sychron to the first, then the node should be a child of the 1st slider. If the slider moves independently, you need an own animation or kinematic to fullfill this task.
Message 9 of 11
ulas_a2
Yes it will act sychron. I want 4 slides like in the video.
How can I do in the form of child items.
https://www.youtube.com/watch?v=sPKEIByGcfk
Message 10 of 11
ulas_a2
Okay Jörg. I found, thanks
Message 11 of 11
joerg_vogel_HsH
