Duplicate objects (multiprocessor, processor, operator) in code?
hai_l2
Message 1 of 8
hai_l2
[ FlexSim 20.1.2 ]
Is there a quick way in code to duplicate the existing 3d object and its settings?
I have a default multiprocessor defined that I like to duplicate and relocate during model reset.
Replies (7)
Message 2 of 8
Matthew_Gillespie
You can use the createcopy() command. For example:
Object defaultMultiProcessor = Model.find("MultiProcessor1");
Object newObject = createcopy(defaultMultiProcessor, model());
newObject.location = Vec3(5, 5, 0);
Matthew Gillespie
FlexSim Software Developer
Message 3 of 8
hai_l2
Thanks for the reply. Does that copy the object and all of its settings?
Message 4 of 8
Matthew_Gillespie
@Hai L2 Yes, it duplicates the object.
Matthew Gillespie
Message 5 of 8
joerg_vogel_HsH
That works with fixed resources and simple flow items, but any object that inherits coupling nodes get problems with a simple copy command. Module objects like AGV paths, conveyors, some taskexecuters and people module aren’t made for this easy method.
Message 6 of 8
hai_l2
Do you mean the links between objects or other assignments are not copied?
Message 7 of 8
joerg_vogel_HsH
There are objects that are members of a group in a system. These behave a bit different when it comes to copy them. A processor or a multi processor are simple fixed resource objects. You can copy them. I wrote my comment, just for those who find this question and think the command “createcopy” works always.
Message 8 of 8
mikael_bs
Can duplicating racks this way cause issues with the Storage System?
