- Mute
- Permalink
- Report
[ FlexSim 17.2.2 ]
I am trying to get sum of the physical length of all items in a queue. I think a "SUM" clause will do that, but I can't get even a reference to a single item in the queue. I tried the adjusted approach in Flexsim 16 and it worked. In the current version Flexsim 17.2.2 I get a table which contains "no data" entries. I have tried to cast the queue into different datatypes, which doesn't change anything, I have tried to get a reference by a rank, that doesn't work neither. The Tutorial method does not work from the section "Advanced Query Techniques" under "SQL queries". Passing the Flexscript function in Dot-syntax or classic structure makes no difference. If I execute the code in a script window, doesn't change anything. What is the current syntax to query the items in a queue?
