How to add columns dynamically to a data recorder?
arunTTT2P
arunTTT2P
[ FlexSim 17.2.2 ]
I am facing a situation in which, I have to add columns to the data recording tab in the statistics collector through code with necessary field values or options.
For instance, if I want to display some global table cell values in each columns and the number of cells to be displayed in the chart varies during different model starts.
three-processors.fsm
Arun KR
JordanLJohnson
The statistics collector was not designed to have a dynamic number of columns. If you are looking for a way to display a global table in the dashboard, you can use one of the dashboard widgets to do that. If that isn't what you want, maybe provide a mock-up of the table you want, and we can see if the Statistics Collector could be used to create that table.
Jordan Johnson
Principal Software Engineer
