Help modeling probability distribution for number of consecutive totes
lambert
Message 1 of 15
lambert
[ FlexSim 22.1.1 ]
Hi, I am trying to model the induction of totes into a conveyor based on a forecasted probability (weight).
So far I am using the following empirical distribution:
Now, I would like to add in variability in terms of the number of consecutive totes for the same arc that go into the conveyor.
In other words, I would like to have parameters that increase/decrease the probability of having more/less consecutive totes for the same arc:
for example:
1-4-6-1-3-1-6 vs 1-1-1-4-6-6-3
does anyone have any ideas on how to model this?
In my head the expected behavior would be something like this:
Thank you in advance,
Lambert
Replies (14)
Message 2 of 15
jason_lightfoot_adsk
The weight give the increased chance of having two consecutive totes on the same arc if you're sampling for each tote.
If you're sampling for a each slug of totes going to an arc, then you can do that in a seperate lookup but then sample less frequently from the the empirical distribution. That then mean the empirical should represent the spread of consecutave totes and not the total spread of totes, meaning you data should be changed to reflect that (if it's the spread of totes currently).
Message 3 of 15
lambert
Thanks Jason
"The weight give the increased chance of having two consecutive totes on the same arc if you're sampling for each tote. "
This makes sense.
How can I then add some variability to the weights defined in the empirical distribution attached to the source of totes?
for example, for arc 1, 15 plus/minus a random probability distribution
Message 4 of 15
lambert
Message 5 of 15
lambert
Hi good morning,
could anyone tell me how to add some variability to a Empirical Distribution?
I'd like that with each replication of the simulation it takes different values.
For example, for Arc 1, instead of a fixed 15 weight, i'd like to use Normal (15, 2) that varies with each replication
Lambert
Message 6 of 15
FelixMoehlmann
You could set the distribution weights in the model reset trigger and use a global table to store the respective distributions (make sure to 'Assign FlexScript Data' to the table cells).
// Reference to distribution table and source table
treenode distributionBundle = Model.find("Tools/EmpiricalDistributions/EmpiricalDistribution1>variables/data");
Table weightsTable = Table("EmpDistWeights");
// Create array of weights based on table
Array weights = Array(weightsTable.numRows);
double sum = 0;
for(int index = 1; index <= weights.length; index++)
    weights[index] = weightsTable[index][1];
    sum += weights[index];
// Scale to 100% and assign to distribution
    weights[index] = weights[index]/sum*100;
    setbundlevalue(distributionBundle, index-1, 1, weights[index]);
This will of course only yield different results, if the 'Repeat Random Streams' option is inactive or for different replications of the experimenter.
Variable_EmpDistribution_fm.fsm
Please consider posting a new question the next time, if it doesn't directly relate to the topic of the previous one.
Message 7 of 15
lambert
@Felix Möhlmann
Thank you Felix, it seems to work fine except for some totes that do not get anything assigned (arc remains blank)
do you know what can be the reason?
updated: seems to be related with the decimal points.
now when I click in generate samples, i get the following error:
exception: FlexScript exception: Invalid row identifier forVIEW:/active/EmpiricalDistributionProperties2700133680/GenerateSamples/popup2699292528/BarChart>variables/dumpData at VIEW:/active/EmpiricalDistributionProperties2700133680/GenerateSamples/popup2699292528/BarChart>eventfunctions/getData c: VIEW:/active/EmpiricalDistributionProperties2700133680/GenerateSamples/popup2699292528/BarChart
thank you
Message 8 of 15
FelixMoehlmann
Looks like a bug. I get the same with a fresh model/distribution when changing the data type around a lot.
It seems like the Variant returned by Empirical().get() is not always interpreted as the correct type when assigning it to the bundle that holds the sample data.
If I run the same code but cast the Variant as the respective type (...as(double)) it works consistently.
For now I can only offer the workaround to test the distribution 'manually' by writing sample data to a global table, link that to a calculated table and plot it in a dashboard chart.
Message 9 of 15
lambert
Thank you Felix,
One last question,
if I run the same script through another trigger in the middle of a simulation run, would it dynamically adjust the values for the empirical distribution and the simulation will use the new values mid-run?
thank you
Message 10 of 15
FelixMoehlmann
No, the distribution is 'fixed' on reset. Changing the source table without resetting afterwards will not change the returned values.
You could build your own custom command that returns empirical values based on a global table instead. It might be slower but that shouldn't really be noticeable. This would allow you to change the values in the source table it is based on during the model run and have it affect the distribution immediately. (Emulating the weighted discrete distribution isn't too difficult; the complex function of the empirical distribution tool is to create continuous values based on example values)
Variable_EmpDistribution_fm_1.fsm
Message 11 of 15
lambert
Hi @Felix Möhlmann , is there some way for me to send you a private message?
please let me know, thank you
Message 12 of 15
Sorry we missed this.
If you comment and then accept an answer as was the case here - it can disappear from our tracking system. While you require follow-up please do not accept the answer after a follow-up question.
Message 13 of 15
lambert
@Felix Möhlmann hi Felix, is there somewhere I can reach out to you privately? thanks
Message 14 of 15
FelixMoehlmann
If you require more in depth support than the forum can provide please contact your local distributor.
You should see the contact information on your FlexSim Account page.
Message 15 of 15
julie_weller
Are you still struggling with this follow up question? If so would you want to post it as a new question? Thanks in advance!
