Global variable Array with Array elements
jarek_o
jarek_o
I would like to make an Global Variable with type Array, containing Arrays as elements.
example:
Array[2]: Array("foo",1), Array("foo",2);
It doesn't seem to be that easy for me.
Flexsim version: 17.1.6
arunTTT2P
Hi @Jarek O,
Here's a simple example.
First you create a global array variable manually, then you can insert array elements through code.
int rows = 5;
Array DataArray = [5,3,2];
Array array = Array(rows);
array.fill(DataArray);
GlobalArray = array;// GlobalArray is the global array variable
Arun KR
jarek_o
Is this working for you? For me it doesn't work, I tried similar things as well, but nothing that succeeds.
Jarek
arunTTT2P
yes, just see the return value on the script console.global-array.fsm9184-global-array.png
jarek_o
yes @Arun KR, but it isn't stored in the GV? If you run that script, it returns indeed that array, but the global variable itself is still empty in further use.
Jarek
arunTTT2P
I was able to reproduce the changed global array in a label array in a Queue.
But you will not see the value change in the tools menu of global variable.
Pls check the model. global-array.fsm
