how to change the position of an axis ?
mohamed_slama
mohamed_slama
I want to rotate a 3D object by the Z-axis translated. In FlexSim, the axis go through the center of the object but what I want is to rotate the object around an axis parallel to the Z-axis but going through the extremity of the object.
Slama
jing_chen
Hi, @Mohamed Slama
You should find the "centroid" variables under the treeview of the object, and set its value to 2. Then Add 3 child node with numeric type whose value should be between 0 to 1 that means the ratio of 3 axises.
Here is an example pic:
jing_chen
@Mohamed Slama
Hi, It seems your comment lost, but fortunately I can find it in my e-mail.
philboboADSK
It is possible that Mohamed Slama figured out the answer to his own question and then deleted the comment.
Phil BoBo
Sr. Manager, Software Development
