FlexSim on a Macintosh
ganchimeg_myagmarsuren
Message 1 of 14
Does FlexSim work on a MacBook? I downloaded FlexSim Express to my laptop, but Windows versions do not work. Where or how can I get a Mac OS X version?
Replies (13)
Message 2 of 14
Ben_WilsonADSK
FlexSim is currently a Windows-only software (see FlexSim's system requirements). In order to run FlexSim on your Mac, you will need to either dual-boot into Windows (using Bootcamp), or virtualize a Windows installation on top of macOS (using Parallels, VMware, or some other virtualization solution).
Dual-booting usually results in better performance, especially for a graphically intensive program like FlexSim. It allows the operating system to have direct access to the hardware.
With virtualization, your mileage may vary. Different software and hardware vendors, and drivers, support virtualization to greater and lesser degrees. You may find that FlexSim's performance is not as good when running on a virtualized system, or you may run into stability or other issues.
UPDATE: As mentioned in comments below, FlexSim works very well using the latest version of Parallels, even on Apple silicon like their new M1 chip.
There are currently no plans to support the Mac platform.
UPDATE - July 2022: FlexSim is actively exploring going multi-platform to support both macOS and Linux, in addition to Windows. There is not currently a timeline or estimated release date.
If anyone in our community can chime in with their experience with FlexSim on a Mac, or any tips to getting the most from virtualization, please add your voice to the comments below.
Message 3 of 14
Ben_WilsonADSK
We've recently had a good experience with the very latest version of Parallels. It appears that it has better OpenGL support. Our initial impression is that it fully supports FlexSim's 3D requirements, though because it is virtualized your performance will still be inferior to dual-booting directly into Windows.
If you've tried FlexSim using the latest version of Parallels, please share your experience below.
Message 4 of 14
tee_hiett
Ben,
Have you had any additional experience with FlexSim on the Mac?
Message 5 of 14
Ben_WilsonADSK
Hi @Tee Hiett,
Our Mac reports come from experiences shared with us by our users, so I can't tell you what exactly worked and what didn't, only that we've had a few users on the latest Parallels and it worked well.
Dual booting directly into Windows is always going to be the best option, performance-wise, but VM platforms like Parallels are always getting better.
Hey @Matt Long, do you have Parallels? Any chance you can boot into MacOS and test Parallels for us?
Message 6 of 14
philboboADSK
One user recently told me this regarding his Parallels experience:
"I finally had a chance to test out using Parallels 15, and FlexSim 19 appears to run great on it. I’m using the Core profile, and that’s all I had to change to make it work well. It looks like they [Apple] fixed the issue I observed before where objects weren’t selectable.
I do notice a slight (maybe 300ms) delay between when I click to zoom or pan on larger models… but it’s not bad.
I’ve noticed that whenever I suspend the VM and then resume it, the 3D model view in FlexSim goes completely black. The only way I’ve found to fix it is to restart FlexSim. I’m not sure what is causing it."
Phil BoBo
Sr. Manager, Software Development
Message 7 of 14
sofia_na2
Hello, I would like to know if there are still no plans to support the Mac platform?
Message 8 of 14
Ben_WilsonADSK
@Sofia Na2 Multi-platform FlexSim is in active development, though there is currently no estimate for when it will be ready.
Message 9 of 14
philboboADSK
I just installed FlexSim on a MacBook Air (M1, 2020) with macOS Monterey using Parallels Desktop 17 with Windows 11.
FlexSim installed and ran without any issues. FlexSim also has working OpenGL 3.3 graphics acceleration without customizing any settings. Instanced rendering, shadows, and bone animations are all working properly.
Using Parallels to run FlexSim on a Mac is still viable, even on Apple silicon.
Phil BoBo
Message 10 of 14
ralf_gruber
I also tried FlexSim in Parallels Desktop on a 2021 M1 Macbook Air. I was actually surprised, how smooth the experience was, even with larger models and heavy 3D graphics. The one thing that I found not being right was this:
After hitting the New Model button, a texture was rendered with the model background, although none was selected:
Looked like some clothes texture for an operator. When deleting the background everything worked fine, until I dragged a Plane object into the model:
Same texture as above. Maybe just a settings thing?
However, although there were these two little setbacks, the overall behavior was great!
Message 11 of 14
philboboADSK
That looks like a driver issue. I'd make sure that the macOS is all up-to-date and that you've installed the latest Parallels updates.
Phil BoBo
Message 12 of 14
ralf_gruber
MacOS needed an update. That solved it. Thx
Message 13 of 14
clair_augsburgerZGWRZ
Hi @Ben Wilson , about this comment:
Are you also exploring to support Linux for hosting FlexSim server licenses ?
Message 14 of 14
Ben_WilsonADSK
Licensing components, including utilities for license servers, would also be rebuilt for macOS and Linux as part of the multi-platform push.
Again, there is no estimated timeline.
