Flexscript Error: syntax error, unexpected ':', expecting end of code
maryamh11
maryamh11
[ FlexSim 21.2.4 ]
Beta 2022
Model_global_table_times.fsmVersion Beta 2022
I've set a global table to be able to read specific times from there and do a calculation. The type of the cells are set as string in that column, but I am constantly getting this error:
Could not finish parsing because of previous errors.
Can anyone help to solve this?
A snippet of the model is attached.
moehlmann_fe
"executeCell()" interprets the content of the cell as FlexScript, leading to the error. And in your custom code you are trying to subtract two strings from each other (third column value). That is not a valid operation.
If you want to get a difference between two times of day, I'd suggest to use the Model.dateTime class.
https://docs.flexsim.com/en/21.2/Reference/CodingInFlexSim/FlexScriptAPIReference/Data/DateTime.html
The properties "hour", "minute", "second" and "millisecond" allow you convert the current time of day into a decimal number that can then be compared to a given time in the table.
For example, instead of 08:00:00, you simply write 8 (as a number) into the table.
Model.dateTime.hour + Model.dateTime.minute/60 + Model.dateTime.second/3600
will give you the current time of day (for example 8.607 for 08:36:25). Then you can get the time difference as 0.607 hours.
maryamh11
@Felix Möhlmann Thanks for the answer!
If the time difference value leads to a negative value and I use that value in the "Delay" activity does the Delay activity take into account the negative values as 0?
moehlmann_fe
Yes, negative values will be treated as 0 in a delay activity. In other places (for example the quantity field of a "Create Tokens" activity) a negative value might lead to errors. To be save you can use "Math.max(value, 0)" to return 0 if the value is negative.
maryamh11
Got it, thanks!
