Experimenter problem
Yu_Han
Yu_Han
[ FlexSim 22.2.0 ]
Can the order of the items output on the Queue be used to find the best order using the experimenter?
If possible, can you give me an example of how the parameters should be set...
Jeanette_Fullmer
Hi @Han,
It's hard to know how to help without looking at your model. To receive a more accurate solution, please post your model or a sample model that demonstrates your question.
Proprietary models can be posted as a private question visible only to FlexSim U.S. support staff. You can also contact your local FlexSim distributor for phone or email help.
Yu_Han
experimenter problem.fsm
The above file is a model
joerg_vogel_HsH
optimizing order is currently a variation of combinations. Then you are responsible to release items in different order yourself. 3D logic with connections and triggers uses commands like releaseitem to control a script based flow. Process Flow uses moveobject activity.
For an experimenter setup you can write different variation strategies into a send to port function which you can activate by a parameter or label value. You change in experiments these values then. I would activate in statistic menu “repeat random streams“ and in experimenter repeat scenarios to one. This applies well to find an optimized order for a timed process. If you are interested in Machine Learning features of FlexSim you should consider to deactivate “repeat random streams” and use large values for repeating scenarios.
natalie_white
Hi @Han, was Joerg Vogel's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
lifeng36912
Observer
Observer
 hello,i meet the same problem ,can you show a example,thanks
