tokens tanfer objects based on labels
ahmed160118
Message 1 of 1
ahmed160118
In my model, I created a Process Flow that gets order labels from a global table.
  • Each token = one order (with labels like NumBobbins, Priority).
  • I have a queue “Bobbins” with bobbin objects (each has a BobbinType).
  • I want to transfer bobbins from Bobbins to Staging based on the order’s NumBobbins.
    • Example: if NumBobbins = 3, then move 3 bobbins with the same BobbinType.
    • Select bobbins with the minimum Priority first.
  • The bobbins moved should be linked to the order and take on the order’s labels.
My question:
 I tied the token’s Priority label as a parameter, but is this the correct way for it to work with the Optimizer?
Replies (0)
