ExitTransfer Question - The Operators do not pick up the item at the end of the transfer
raashid_mohammed1
Message 1 of 9
raashid_mohammed1
model06-01-2016-currentstate-8am.fsm
See attached model
I am trying to send totes to from conveyor to different combiner location by its label ToteID
but the operators they don't pick up the end items
If you run the model till 3500 seconds you can see the operators are picking the items coming down from the conveyor not the one waiting for the conveyor
Please help
Regards
Raashid
Replies (8)
Message 2 of 9
Matthew_Gillespie
This looks like a bug with the Exit Transfer and we'll be looking into it.
A work around you could use right now would be to put a queue in front of each of the combiners and then connect the exit transfers to the queue rather than the combiner.
Matthew Gillespie
FlexSim Software Developer
Message 3 of 9
Matthew_Gillespie
On a side note, I simplified your process flow in the attached model from this:
To this:
That should make your model easier to work with and maintain.
Matthew Gillespie
Message 4 of 9
raashid_mohammed1
Thank you
I also seeing that operators are going through the conveyor
IS there a way we can avoid that
When they start to pick the item on the conveyor they walk through the conveyor
I have added network node and Astar does not work for both
See attached
model06-01-2016-currentstate-12pm.fsm
Message 5 of 9
Ben_WilsonADSK
@Raashid Mohammed, this forum works a little different than our old community forum in that each "Answer" is meant to be an actual answer to the question, not a reply to a previous post.
Post-reply conversations are meant to be done in the comments of each answer. This makes finding answers easier for people who are skimming, so I've converted your answer into the comment above.
Also, new questions should be posted as their own question, not added to existing questions. The question you pose in the comment above is reposted here.
Message 6 of 9
raashid_mohammed1
Thank You Ben
Trying to Learn the new format 🙂
Message 7 of 9
joerg_vogel_HsH
@Ben Wilson, where can I find how to use the new forum format. I am not using the modern social media on my own, but you expect all users do that. Where is the manual to read? Otherwise it would be better manner to write an e-mail instead of a comment and then place a sticky thread for the rules here at answers.flexsim.com.
Message 8 of 9
Ben_WilsonADSK
Great point @Jörg Vogel! I just posted an article here that can be the starting point for a "user manual" for answers.flexsim.com.
I hope that no one has been offended by our gentle pushes for how to use the site to this point. We purposely added these pointers as comments so that others could also see and learn how to use this site, not to publicly censure anyone. Hopefully there aren't any hard feelings, but if so, please accept our humblest apologies.
Thanks to everyone who has been using answers.flexsim.com! And again, here are some tips to help keep this community running smoothly and stay organized:
https://answers.flexsim.com/articles/22192/best-practices-for-using-this-answers-site.html
Message 9 of 9
Matthew_Gillespie
This bug has now been fixed and will be out in the 16.1 release.
Matthew Gillespie
