Distance between departments in the layout
dilla_da
Message 1 of 26
dilla_da
[ FlexSim 22.2.0 ]
[URGENT]
Please help me to determine the distance between departments with the following data:1744353187154.png
I have attached the model below:
percobaan 1.fsm
Please include the answer in the model provided:
Replies (25)
Message 2 of 26
yuechao
I downloaded your file, but when I opened it I see nothing
Message 3 of 26
dilla_da
I'm sorry, this my file version 22.2 percobaan 1 (1).fsm
Message 4 of 26
joerg_vogel_HsH
If these are distances on a network without any offset travel, then you can assign virtual distances for a network node network.
Message 5 of 26
yuechao
You can use the command to get about distance between A and B.
Message 6 of 26
dilla_da
Sorry, Can you send it in simulation form, please.
Message 7 of 26
dilla_da
@Joerg Vogel Sorry, Can you send it in simulation form, please...
Message 8 of 26
chanykE2WUT
@Dilla Da This is your school home work. Should it be your role as a student to explore?
David
Message 9 of 26
dilla_da
sorry this is not my homework, this model is just an example
Message 10 of 26
chanykE2WUT
@Dilla Da Please look into the User Manual about Network Node. You should be able to explore more information about virtual distance.
David
Message 11 of 26
moehlmann_fe
Here is an example model. As Jörg and David mention, you can use the Virtual Distance on network nodes if you want to enforce an exact travel distance.
Make sure to make this setting on both sides of a connection since each network node is only responsible for one direction.
virtual-distance-example.fsm
Message 12 of 26
joerg_vogel_HsH
Message 13 of 26
dilla_da
Ok thank you. why each workstation transporter is not working on Default network navigator. Please provide an example in fsm form
Message 14 of 26
dilla_da
Ok thank you so much
Message 15 of 26
moehlmann_fe
I am not sure what you mean. The example model works and Operator or Transporter are interchangeable. Is everything (processors and transporters) connected to the network?
Message 16 of 26
dilla_da
1. Transporter 2 is connected to NN1, not NN3, where NN3 is on the lathe. Please help.
2. Then, transporter1 does not return to the raw material storage when it is working; it just stays on the lathe. What is the solution?
3. How to solve the problem above?
I have attached the model below. Please help me.
Message 17 of 26
chanykE2WUT
@Dilla Da if your first problem is resolved, please start another thread for the new question.
All objects using the network must connect to the network. The destination that mentioned is not connected to the network.
David
Message 18 of 26
dilla_da
what is the solution to my problem?
Message 19 of 26
chanykE2WUT
The solution is to connect the destination object to the network.
David
Message 20 of 26
moehlmann_fe
Each transporter needs to start connected to a node on the network/path it's supposed to travel on.
None of the network nodes in your model are connected to any object.
To have a transporter return to a default location when idle, use one of the options in the "On Resource Available" trigger.
I have connected the NNs and transporters based on my best guess what looks correct.
percobaan-1(1).fsm
