Derived /Expression Value Columns In Object Property Table
arunTTT2P
arunTTT2P
[ FlexSim 24.0.0 ]
Is it possible to have derived values/expressions as a column value in the object property table? By using a label we can do that, other than using a label is it possible?
Arun KR
jason_lightfoot_adsk
Can you just use the table query to create your table and use a custom expression or user command in the query?
Table.query("SELECT Object, Name, myexpression(Object) FROM Objects()").cloneTo("CustomPropertiesTable")
