Creating table on Dashboard showing time in State
jamesriebau
jamesriebau
How do I create a table on a dashboard that show the amount of time spent in each state?  I only have the option to add a pie chart or bar chart by %.  I can click view table on the pie chart to see the information I want; but how do I show on the dashboard?  In this case I'd just want to show only the used states.
Jim
moehlmann_fe
You can (sort of) show the actual times in the pie or bar state chart. If you uncheck the "Show Percentages" option FlexSim will display the actual time values when hovering over a bar/pie segment.
To get the values in a table, install the components of the chart to make the Statistics Collector accessible. Then you can use a Calculated Table to only select the states with a time > 0 and display its result on the dashboard.
jamesriebau
Thanks, this worked for me.  I was able to copy what you did in your sample and make it work in mine.
