crane and operator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi everyone,
I'm modeling some Fluid-to-Item machines that produce according to a global table. When one of them finishes its production, a crane loads a mold from a queue and unloads it onto the Fluid-to-Item machine, with an operator assisting in the mold change.
I’ve set the machines to stop after production, but I can’t figure out how to call two task executors to pick up and change the mold. Could you please tell me the simplest way to do this — whether by using a process flow, trigger, dispatcher, etc.? or please introduce a source to be similar.
I’m using flexsim 2022 Update 2, so if your flexsim version is higher and you provide a solution, please attach a screenshot because I won’t be able to open your model file.
Also, if you have a good solution just for the crane without the operator, I’d be glad if you could share it.
Thanks!
