Can FlexSim draw logarithmic scale graphs?
yokota_t
yokota_t
[ FlexSim 22.0.11 ]
Hello all,
Is there a way to display a semi-log graph on FlexSim without using DLLs?
If possible, please let me know how to do it.
JordanLJohnson
We don't have support for a log axis. However, charts usually have an underlying table. For most of the charts in the dashboard library, you have to "install" the chart to be able to edit that table. Once you have access to the table, you could modify it so that it takes the log of all the data in the column for your axis. Then 1 on the axis would mean "10", and 2 would mean "20". So the axis labels would be confusing, but the picture would be correct.
Jordan Johnson
Principal Software Engineer
yokota_t
Thank you for your response. It's helpful.
