How to set a Matrix /Coloumn stacking secquence in a Gravity Flow Rack?
AjayManneni
AjayManneni
[ FlexSim 22.2.0 ]
Gravity flow stacking problem.fsm
Hello all,
I attempted to replicate the sequence of stacking in image 1 below on a gravity flow rack, but the results were not as expected (picture 2)
Picture 2 (Stacking sequence in a Gravity Flow Rack)
I tried customizing the "Slot assignment strategy," but I was only able to arrange the item sequence in the order below.
I also tried modifying the code in the corresponding scripts, but it wasn't successful.
In order to make better use of the space, I would like to put multiple items into a single slot in a matrix or coloumn passion rather than just one.
Is there a method or procedure to get the sequence order in figure 1 on a gravity flow rack?
Any advice or assistance?
Greetings and Thank you in Advance!
joerg_vogel_HsH
You can add more smaller slots
(width 0.1; slots per bay: 25, deactivate storable slots near frame work).
But I think a vertical stacking is not a classic storage option of a gravity flow rack. You can still add a shelf tilt amount in a standard rack.
andrew_o2
Hi @Ajay M, was Joerg Vogel's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
