Generating token based on probability and distribution
Vns
Vns
[ FlexSim 22.0.8 ]
Hi -
im not quite sure if there is a way to generate tokens based on the following conditions:
Set a probability for token creation for each hourly slot. In the event a token where to be created set a randomize quantity distribution to be generated.
Time intervalProbabilityQty
0600 - 065920%1 - 4 (2)
0700 - 0759
50%1 - 4 (1)
0800 - 0859
10%1 - 4 (4)
Thanks in advance.
moehlmann_fe
To use different expressions for the hours of the day, it would be best to use the "Date Time Source".
One way to either create no tokens or a random number is to just multiply two distributions together. "bernoulli" can be set up to either return 1 or 0 with the given probability. So only if it returns 1 will the quantity be something other than 0. The second distribution controls the quantity if it does return 1.
jason_lightfootVL7B4
bernoulli takes a percentage value not probability - so bernoulli(20,1,0) gives 20% chance of returning 1.
moehlmann_fe
Right, that's an oversight on my part. Thanks for the correction.
Vns
Thanks @Felix Möhlmann / @Jason Lightfoot for sharing the inputs.
I can't seems to get the model to run to generate the tokens based on this setup. Is there a step that i missed? probability and distribution.fsm
moehlmann_fe
Put the expression into the Arrival field at the bottom that appears when you have a table cell selected, not into the table directly. (Writing it into the cell directly interprets it as text, not FlexScript).
In your case the resulting table should look like this:
You only see the first row of the code that gets auto-generated when you type in the expression. This was changed in version 22.2 which my screenshot above is from.
Sorry for the confusion.
