Base on the GlobalTable value to run the model.
s1125413
s1125413
Hello FlexSim community and @FelixMoehlmann .
I'm studying that FlexSim will regular monitoring the value in database. when the value changes to 1, the model will be run. Is possibility or any methods and  advice to implement this?
Thank you in advance for your help.
joerg_vogel_HsH
Flexsim must already run a model, then you can check a value to do something. In this scenario you can let resume a process flow or a stopped source object. If you want to start the Program Flexsim then you have to evaluate a value from a scheduler process in windows system.
s1125413
Thank you @joerg_vogel_HsH
Now I can open the model through the database and Python, but I want the model to run automatically when it opens. However, it doesn't work. Do you have any advice?
s1125413
I add resetmodel() before run model and it work!
joerg_vogel_HsH
