AUTOCAD COORDINATES ISSUES
agustin_adam_fo
agustin_adam_fo
[ FlexSim 21.2.4 ]
Hi, I'm trying to import 3 AutoCads with specifics coordinates but Flexsim shows them overslapped.
The coordinates are in the fsm
This is the FlexSim model:
Opcion2.fsmPlano2.dwgPlano3.dwg
SebastianCanasV
Hola @Agustin_adam Fo,
Cuando se importan planos a FlexSim se ubican según coordenadas cartesianas en el lienzo de trabajo de la vista 3D. En este aspecto también influye la forma en que fueron realizados en el software AutoCAD.
Para este caso puntual, asegúrese si las coordenadas que se le dieron son coordenadas cartesianas o coordenadas geográficas. Según sean el caso, el resultado final al ubicar las coordenadas que se le otorgaron puede variar.
SimFlex_support
@Agustin_adam Fo
It looks like normally importing 3 dwg files.
You can control them to locate the right position by using mouse.
You can set 'No Select' flag unchecked like attached.
The result model is attached also.
opcion2.fsm
email ID : support@flexsim.co.kr & support@simflex.co.kr
connor_a
Hi @Agustin_adam Fo, was one of David Seo's or Sebastián Cañas's answers helpful? If so, please click the "Accept" button at the bottom of the one that best answers your question. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
