About Kinematics
About Kinematics
3250716938
About Kinematics
3250716938
[ FlexSim 22.2.0 ]
I want item move and rotate in same time when it arrival DP1, but it seems not work, how do I can finish that?
demo.fsm
FelixMoehlmann
Items on conveyors are moved by kinematics which will overrule any additional movements you define. To affect the item's position/rotation on a conveyor, you have to use the movement options in the decision triggers.
capture1.png Note that moving the item along the conveyor direction will not change the timing of when future decision points or exit transfers are triggered. The offset defined by these options is purely visual.
