A bug of sql union all
yexioamu
yexioamu
[ FlexSim 21.2.4 ]
a bug of union all sql.fsmWhen i create a GlobalTable ,then use union all, the rows of result is incorrect, it is the last select limit nums。
what can i do for it?
Jacob_White
Hi @yexioamu,
Thank you for contributing to our community! We couldn't identify a maintained license or subscription linked to your account.
You may need to update your profile information to identify yourself as a license owner or their associate. Check out our article for how to ensure you receive timely support. If you update your profile comment back to let us know - we'll adjust the priority of your post accordingly.
If your current license is expired, please contact your local distributor to renew.
yexioamu
how about now? my company account shares with me
FelixMoehlmann
I have found two possible workarounds:
Nest the select clauses in another select that simply copies the results.
Table.query("SELECT A FROM (SELECT A FROM table WHERE A = 1 LIMIT 2)\
                        UNION ALL\ SELECT A FROM (SELECT A FROM table WHERE A = 2 LIMIT 2)");
Or add an extra select clause at the end that you know won't return anything but doesn't have a limit.
Table.query("SELECT A FROM table WHERE A = 1 LIMIT 2\
                        UNION ALL\                         SELECT A FROM table WHERE A = 2 LIMIT 2\                         UNION ALL\                         SELECT A FROM table WHERE A = -1 AND A = 1");
yexioamu
It works well, thx!
Although this operation may seem a bit strange, it does not comply with SQLite syntax, then we use a complex method to avoid it
