Hi @我才是馬邦德 ,
I just tested the following steps, and it worked for me on a fully patched and upgraded Windows 11 Enterprise system:
- Install Amazon Corretto JDK 11 (Amazon's index site, direct link to Windows x64 .msi installer).
- Install lmadmin 11.19.2.0, downloaded from FlexSim, choosing all the defaults.
- I checked the box to install Visual C++ Redistributable.
I may be wrong, but from your final screenshot it looks like the installer doesn't even finish extracting, let alone run. I suggest making sure your Windows installation is fully updated and patched. Reboot before running the Corretto installer. Reboot before running the lmadmin installer. I never had to reboot, but that is something you can test if you continue to run into issues.
And if you're using some other version of Java besides the one I just tested with, I don't know what to suggest, other than go with FlexSim's preferred solution of lmtools, or if you must use lmadmin, try it with Corretto.
Good luck!
