Hi ayanazafeera,
As far as I am aware, I never created a Batch Tutorial for Matchbox because it is really easy to use in Batch.
I did the Action videos because of how Matchbox tools can be applied to maps, camera and how they access 3D information from Action. None of this is required for using Matchbox in Batch. You treat it like any other node.
For example, in the Batch Node bin, just look for the Matchbox node. Drag it out and it will launch the file browser. You choose your Matchbox tool and it will be applied to the node when you return to batch.
All that is is left is to do is to connect your inputs and go into the Matchbox node and start tweaking settings.
Does that answer your question or is there anything particular you are looking for?
Regards
Grant
Grant Kay
Principal Learning Content Developer
The Official Autodesk Flame Learning Channel
http://www.youtube.com/flamehowtos
The Official Autodesk Smoke Learning Channel
http://www.youtube.com/smokehowtos
Also available as podcasts on iTunes
Follow me on twitter @discreetuk for the latest training updates.
