I've built a matchbox shader but I can't find a way to force it into making the input 32bit by default. Any ideas? At the moment I have to manually T-click the source and then change the matchbox shader to 32bit. I'm using a UV map inside the shader if you're wondering why it needs to be 32 bit.
Cheers,
Drew
