Thread from curve
Thread from curve
cyoungblood87
Observer Observer
Message 1 of 17
Thread from curve
cyoungblood87
Observer
Observer
I have a romi with Fanuc 21i-t and i am threading from curve. Need some help figuring why the thread starts at 5.75 dia instead of the 4.875 dia that it’s programmed at. The simulation shows it starting at the correct dia.
Replies (16)
Message 2 of 17
Hi @cyoungblood87,
Can you share the part.
Message 3 of 17
TomOliver
Have you checked the clearance amount in the thread attributes?  Also, what simulation are you using? Centerline or 3D?
___________________________________________
Inventor Professional
Autocad LT
FeatureCam Ultimate
Fusion 360
Message 4 of 17
abhishek.juvekar
Hi @cyoungblood87,
Welcome to Autodesk Community!
Can you please check 'Start clearance' in threading attributes?
Thank You.
Abhishek
Message 5 of 17
Mikhail_Voronin
I am having trouble with a thread from curve
version: 2019.1.2.0017
any ideas?
Mikhail
Message 6 of 17
Hi @Mikhail_Voronin,
Can you share the part?
Message 7 of 17
Mikhail_Voronin
Hi, @Anonymous
https://autode.sk/2JOU7jX
Mikhail
Message 8 of 17
I think the toolpath do as expected. see video.
https://www.youtube.com/watch?v=VP3_BVTMifE
Message 9 of 17
Mikhail_Voronin
I don't understand why I couldn't make the thread.
can you send me a simple example?
Mikhail
Message 10 of 17
Mikhail_Voronin
I think there's a problem with the FeatureCAM 2019
Mikhail
Message 11 of 17
See the attached video I have created.
https://autode.sk/2A79swT
Message 12 of 17
Mikhail_Voronin
@Anonymous
thanks a lot it is working
but I would like Thread feature represent a single groove of the thread. What should I do?
Mikhail
Message 13 of 17
This is the closed I could came with a groove.
https://www.screencast.com/t/GuiJ3Qja5E
Message 14 of 17
Mikhail_Voronin
Hi @Anonymous
I meant something else.
Is there a way to make a thread in FeatureCAM 2019 using curve as cross-section
Mikhail
Message 15 of 17
abhishek.juvekar
Thanks for your contribution to Autodesk Forum.
You can either select a curve to define the cross-section (old behavior) or select a curve to define the path of the thread (new behavior). You can't select them both at the same time.
To create a thread from curve,  create a thread feature from dimensions and select a curve.
Thank You.
Abhishek
Message 16 of 17
Mikhail_Voronin
Hi, @abhishek.juvekar
Thanks a lot!
Mikhail
Message 17 of 17
Mikhail_Voronin
Hi @abhishek.juvekar
another possibility
Mikhail
