run basic macro
run basic macro
rfuentes
run basic macro
rfuentes
is there a bug on the latest version of featurecam for running macros? Everytime i click on it , featurecam freezes.
craig.shipley
Autodesk Support
Autodesk Support
Hi
Have you tried to run as administrator?
(right click FeatureCAM shortcut > run as administrator).
Kind Regards
rfuentes
@craig.shipley No i did not. I contacted autodesk but they told me the same thing. To run as administrator. When i do that, featurecam opens but it wont let open any file.
craig.shipley
Autodesk Support
Autodesk Support
Hi
Usually if you are running as administrator and you try to open a file from the network it will not work...
So run as administrator, open a local project (desktop perhaps) or even just create a new project, then run your addins and then on the HOME tab hit "save now"
Kind Regards
rfuentes
ca1838c5-0a1e-4e5f-bc51-9cd447de550e,tps://forums.autodesk.com/t5/user/viewprofilepage/user-id/4043345,tps://forums.autodesk.com/t5/user/viewprofilepage/user-id/4043345
@craig.shipley  hello craig
I followed your instructions but it did not work. I have attached a screen cast so you can see whats happening.
craig.shipley
Autodesk Support
Autodesk Support
I think I know what this is and it’s permission related but as I have finished for the day I don’t have access to my cases...
I will update date tomorrow when I return to work.
Kind Regards
craig.shipley
Autodesk Support
Autodesk Support
Hi
I can see you have a case open for this so I have added myself onto it.
If you could please reply to the case email when you're in work, then perhaps I can connect you your PC using Team Viewer and take a look myself?
Kind Regards
