Message 1 of 8
11:51 AM
I am programming a Mazak Vortex 5 axis mill. the problem is the first operation is using a 2 inch dia face mill at zero deg and when that operation is done i use the same face mill on the side of the part, the CNC code keeps the tool at zero degrees and it should rotate to 90 degrees on the next operation, anyone else have the same issue?
