One of my postprocessors don't work with "NC code text". I try add M00 to program, but this missing. I traywith another post, and all is ok. When add toolpath with NC code text, the text is missing and 2 rows down M9 is missing. I tray to turnoff row by row in "toolchange", buth no result.
Solved by grandeurvox. Go to Solution.
Solved by ChristopherMarion. Go to Solution.
Hello @grandeurvox
I attached an updated post for you. It is not a large change.
It should now output the M00 as well as the line number. If you want the line number removed, you can open up the post in Xbuild and:
Remove the {N<SEQ> } from the line there.
If this gives you what you are looking for, just add a solution to this so others know for the future.
The solution is to add this row
{N<SEQ> }{<UDF-TEXT> }{(<UDF-COMMENT>)}<EOB>
in Format/Move/UDF Text in XBUILD
Thank you ChristopherMarion
