grandeurvox
606 Vistas, 2 Respuestas
Postprocessor don't work with "NC code text"
One of my postprocessors don't work with "NC code text". I try add M00 to program, but this missing. I traywith another post, and all is ok. When add toolpath with NC code text, the text is missing and 2 rows down M9 is missing. I tray to turnoff row by row in "toolchange", buth no result.
Etiquetas (6)
ChristopherMarion
en respuesta a: grandeurvox
Hello @grandeurvox
I attached an updated post for you.  It is not a large change.
It should now output the M00 as well as the line number.  If you want the line number removed, you can open up the post in Xbuild and:
  1. Go to Formats
  2. Go to Move
  3. Go to UDF Text
Remove the {N<SEQ> } from the line there.
If this gives you what you are looking for, just add a solution to this so others know for the future.
Christopher Marion
Technical Specialist - CAM
SolidCAD - Canada
grandeurvox
en respuesta a: ChristopherMarion
The solution is to add this row
{N<SEQ> }{<UDF-TEXT> }{(<UDF-COMMENT>)}<EOB>
in Format/Move/UDF Text in XBUILD
Thank you ChristopherMarion
