Parts import very small
jblack
Message 1 of 36
jblack
I've had this issue three times now, twice with a .dxf from AutoCad, and now with a solidworks file.
When I try to import using the "import using exchange", Featurecam thinks the parts are tiny.
I figured it out in Autocad, but solidworks has me stumped. The units in SW are set to inches, and Feature cam is also set to inches. but when I import my part, which should be 8.250"x1.200"x.180", it shows up as .3196"x.0474"x.0071.
I've used Featurecam for about 4 years now, and this is new to me.
I've attached the log file generated by Featurecam to see if that will help.
Replies (35)
Message 2 of 36
Can you share the part?
Thank you,
Jacob
Message 3 of 36
jblack
Sure thing.
In messing around with it this morning, I figured out that it is somehow still scaled for MM, even though it measures as inches in Solidworks.
Message 4 of 36
Look at my video, it looks to be the rigth value.
http://autode.sk/2mz0D57
Can you share your configuration files, these are located on.
C:\ProgramData\FeatureCAM
You should share.
EZFM_mfg.ini
ezfm_ui.ini
ezfm_ui.XML
Thank you,
Jacob
Message 5 of 36
jblack
Thanks for the help so far jd, but the forum won't let me attach the . two .ini files to the post.
Message 6 of 36
You welcome.
Can you zip them? and then attach.
Thank you,
Jacob
Message 7 of 36
jblack
Ahh yes, didn't think about that. Here you go.
Message 8 of 36
There are something strange here, I copied your setting files in my library and imported the part as expected.
I thing you should try to take a backup of the the files there are located in the C:\ProgramData\FeatureCAM.
1. Close all featureCAM app.
2. Create a new folder put all the files in there
3. Then restart FC as admin, and try import the part and see the result.
Thank you,
Jacob
Message 9 of 36
jblack
That seems to have fixed it, thank you sir.
Is there any reason I should keep the copy of those files?
Message 10 of 36
Great to hear.
No, delete the backup-folder, so the files don't trick you again:-)
Have a nice day.
Thank you,
Jacob
Message 11 of 36
jblack
Alright, thank you again.
Have a nice day.
Message 12 of 36
jblack
So this has started again, with files I drew myself, not just customer supplied files. Is there possibly a setting somewhere that is incorrect that's causing it to do this? I did figure out it's scaling the parts as if they're drawn in MM, even though they aren't.
FeatureCAM is set to import in inches.
Message 13 of 36
I dont know where there should be a settings for this.
Could you try to save the files as *.*xt format, then import this and see what happen.
Thank you,
Jacob
Message 14 of 36
jblack
I have tried saving as .x_t, it gives the same results.
We have an older copy of FeatureCAM installed on another machine, and it imports the parts fine, whether in .x_t or .sldprt format.
Message 15 of 36
It sounds very strangs.
Then try take a copy of your files in the folder C:\ProgramData\FeatureCAM on your machine with V2018. copy the files from the old version/laptop to the laptop with V2018 on, and then import as new, and see what happens.
Thank you,
Jacob
Message 16 of 36
jblack
I tried this, with no change. This is becoming quite frustrating. I tried a reinstall of the software, with no change either. I'll attach a copy of the latest log file, maybe there is something in there?
Also, the only way I can get any file other than a .fm file into FeatureCam is to use the Import using exchange function. "Import" nor "Open" will work, they just give me a blank file.
Message 17 of 36
Can you share this part, so I can compare the log files with import.
Thank you,
Message 18 of 36
abhishek.juvekar
Hello @jblack,
Is this happening with native import or import using Exchange? I can import supplied sldprt using file>import correctly in Inch.
Thank You.
Abhishek
Message 19 of 36
jblack
Sure. I'll attach one of the parts, plus a simple block I made as a test. The block should be a 3.75" cube.
Message 20 of 36
jblack
@abhishek.juvekar, I've been relegated to using "file>import using exchange" for months now, because "file>import" no longer works. It only gives me a blank page.
