Hello everyone,
From several days my status bar in right bottom corner missing.
Maybe I or a colleague have changed something in Options Dialog button?
Can anybody help with problem?
I had this problem as well, I think it is hidden behind the task bar. I had to do this to fix it.
https://www.screencast.com/t/kVPTNrCU
Hi @grandeurvox
Just like @bhorstTGM48 said. It may get hidden behind the task bar. I've had this happen in the past.
There is no way to turn off the status/information bar in FeatureCAM.
Hi @grandeurvox
Perhaps your INI file is corrupted. It happens from time to time.
I would try:
FeatureCAM will re-create these files automatically.
Let us know if this worked.
You will need to re-setup your settings in FeatureCAM since everything will revert back to factory settings.
Cheers,
