Importing DXF
Importing DXF
Message 1 of 20
Importing DXF
Just downloaded FeatureCam Ultimate 2020 and cannot import .DXF files that were created on AutoCad. I'll click import, and choose the file. It goes through the motions and asks if I want to see the log. Weather I view the log or not, afterwards the drawing is no different.
Replies (19)
Message 2 of 20
kelbie.ockey
Try navigating to Options > File > Import Types and set Autocad to Exchange.
I was having an issue with this recently as well and passed the info along to development. Exchange gave me better results.
Kelbie Ockey
Sr. Implementation Consultant
Message 3 of 20
It's already there
Message 4 of 20
kelbie.ockey
Did you try setting back to Native?
Kelbie Ockey
Message 5 of 20
ChristopherMarion
@Anonymous
Can you attach the file so we can troubleshoot this?
Christopher Marion
Technical Specialist - CAM
SolidCAD - Canada
Message 6 of 20
Nope..... "Import failed"
Message 7 of 20
It won't let me attach the file. Says the file extension does not match the file. The hell?
Message 8 of 20
Because we are an institution of higher learning we got the free version of the software.... Which means no technical support... Yay...
I called Autodesk to beg for another license for our 2017 software. I know how to navigate the software, it works flawlessly, I can get most jobs drawn in Autocad, transferred to Featurecam, programmed, and dumped into the Fadal and making chips in under 20 minutes. I have now spent 5 hours dicking around with one stupid part. The environment has completely changed. I don't know where half the stuff I need is. This just sucks all around.
When I begged Autodesk for another license for the 2017 software they said "No"... I asked why not?? They said we only go back 3 years. I asked why?? He said because that's how we operate... So I asked him again, why?? And all he could say is "Because that's how we operate"...
Message 9 of 20
ChristopherMarion
Can you try zipping it and then attaching it?
Christopher Marion
SolidCAD - Canada
Message 10 of 20
kelbie.ockey
DXF issue aside, I want to address your issue with 2017. I assume you are frustrated with the ribbon layout vs. the old 'toolbar' layout.
If that is the case, I do want to point out that you can revert to the toolbar in 2018-2021.
To do so:
  1. Hold CTRL and Right-Click the status bar at the bottom of the UI to bring up the hidden menu.
  2. Uncheck Show Ribbon.
  3. You may have to restart FC at this point.
I think this will address your frustration with the new versions. LMK if that helps.
Kelbie Ockey
Message 11 of 20
ChristopherMarion
@Anonymous
I've used the old interface (2017 and below) and the newer interface (2018 and above).  I can feel your pain in trying to navigate it and where to find things.  I suggest ditching the older seat and getting antiquated with the newer versions.  The ribbon interface trumps the toolbar based system, hands down in my opinion.
It will probably take you a few days to find where everything thing is.
Also, there is a way to work with the order interface in the newer versions.  If you are using FeatureCAM to program your equipment, you can do this.  But, if you are teaching students, I suggest just learning the new interface.
We can help here if you need it.  Autodesk never gave support to educational facilities, but you can get that here within the forum if you need it.
Christopher Marion
SolidCAD - Canada
Message 12 of 20
I appreciate the help, but this is all useless to me if I cannot import DXF files into FeatureCam.... No matter what I do the software acts as if it's importing and when it's done there simply isn't anything there. For what it's worth here's a log after the import.
Exchange version:2020.0.0.9052
Input file: C:\Users\lcpeters\Desktop\TMTC.dxf
From format: AutoCAD
Output file: C:\Users\lcpeters\AppData\Local\Temp\DDX58F.tmp.ddx
To format: ddx
sdxOptProcessWireframe:true
sdxOptSendParasolidAsParasolid:true
dtpOptTrimmedSurfaceImport:true
sdxOptExplodeSolids:true
sdxTolMaxFileComplexity:10000000
a2dOptExtrudedCurvesAsSurfaces:false
Called Exchange to execute translation
Exchange translation was successful, importing from Exchange output
Log from Exchange:
Autodesk Manufacturing Data Exchange Utility 2020
Version: 2020.0.0.905203
Build Date: Tue Mar 19 12:48:16 GMT 2019
Status: Full Release
© Copyright 2019 Autodesk, Inc. All rights reserved.
Full Release
Unable to modify resource dtpOptTrimmedSurfaceImport with value true
The input file is C:\Users\lcpeters\Desktop\TMTC.dxf
The format of this file is AutoCAD
Resource file to be used is C:/Program Files/Autodesk/Manufacturing Data Exchange Utility 2020/sys/schemas/resources/AutoCAD.rsc
The following input resource values have been overridden :
sdxOptUseDuctEncoding:true
The output file is C:\Users\lcpeters\AppData\Local\Temp\DDX58F.tmp.ddx
Requested output format is ddx
Resource file to be used is C:/Program Files/Autodesk/Manufacturing Data Exchange Utility 2020/sys/schemas/resources/DDX.rsc
The following output resource values have been overridden :
sdxOptOutputUnits:inch
A voucher has been used for this translation
Reading file C:\Users\lcpeters\Desktop\TMTC.dxf
Writing the translation to C:\Users\lcpeters\AppData\Local\Temp\DDX58F.tmp.ddx
Product ID: Autodesk Manufacturing Data Exchange Utility2020.0.0.905203
Build: Build 03 Tue Mar 19 12:48:16 GMT 2019
License Tier used for translation: PREMIUM.
MEASUREMENT value for this file is set to 0 (Imperial).
LUNITS value for this file is set to Decimal (Undefined).
This file will be treated as if it were written in inches.
You can change this via the sdxOptInputFileUnits (set input file units) resource.
Ignoring empty drawing Layout1.
Ignoring empty drawing Layout2.
5 curve(s) were successfully translated.
1 annotation entity(s) were successfully translated.
.........%10%.........%20%.........%30%.........%40%.........%50%.........
%60%.........%70%.........%80%.........%90%.........%100%
Translation(s) complete
Message 13 of 20
ChristopherMarion
@Anonymous
Can you send me the part to my work email?  I am sure this is a simple issue.
[email protected]
Christopher Marion
SolidCAD - Canada
Message 14 of 20
Just an FYI... The reason I prefer DXF files is because here at the university there are probably a dozen or more different brands of software in use. And some are very antiquated. But all are able to export in DXF. Also 99% of everything we do is in 2D. In the last 15 years, I've had to program in 3D maybe half a dozen times...
Message 15 of 20
AJHanson
Have you tried going to file import options, file types and change Autocad to Native? I don't think we use the exchange any longer.
Message 16 of 20
AJHanson
Have you tried going to file import options, file types,  and change Autocad to Native? I don't think we use the exchange any longer.
Message 17 of 20
ChristopherMarion
@AJHanson
I've got his file and it imports in 2020 & 2021 when the import options are set to Exchange.  When set to native, the file loads in with errors, and no geometry is shown.
We are on the right track!
Christopher Marion
SolidCAD - Canada
Message 18 of 20
I changed Autocad from "Exchange" to "Native" and now it will import... Thank you all!
Message 19 of 20
FYI: It only works if I save the file as DXF 2013 or older... Won't do DFX 2018. Dumb... I'm downloading some software updates. Let's see if that helps...
Message 20 of 20
ChristopherMarion
@Anonymous
I am assuming you are referring to AutoCAD 2013 vs AutoCAD 2018.  If so, you may just need to revert the import option back to native.
Christopher Marion
SolidCAD - Canada
