HAAS SL-10 Post not outputting Feed into the code
f.k.noyes
Observer Observer
f.k.noyes
Observer
Observer
I'm trying to program my HAAS SL-10 lathe using FeatureCAM but when i try and simulate the code on the lathe it gives me an error saying it hasn't been given the feed rate. when looking at the g-code its right and will either skip the feed rate or say "F0." as the feed rate. I've tried looking in the post editor but i can't find what to change to fix the problem.
Am I doing something wrong while programming or is it a problem with the post processor?
bhorstTGM48
I beleive that the.FM file you uploaded is the temp file? It is only 1k in size.
f.k.noyes
Observer
Observer
Sorry about that. I've uploaded it again.
chrisdavid605
The word formatting is not setup for less than 1.
Go into the post > cnc info > word formatting > find feed/rev > click the underlined text > change the metric format from 4.0 to 4.4, this will give you 4 places after the decimal. Your feed for min is setup the same if you want to change that just edit that word the same as the other.
f.k.noyes
Observer
Observer
Thanks for the help. This worked perfectly!
