Geometry point dislplay size
ncpapaul
Message 1 of 25
ncpapaul
How can I change the geometry point display size?   Since I upgraded to 2017 it displays as a really small dot, I can barely see it.  Paul
Replies (24)
Message 2 of 25
AJHanson
Go to Options , Display, Point size I have mine set a 4 pixels. I hope this works for you.
Message 3 of 25
phil.jenningsM7ZMZ
Just to clarify, Select Wireframe to see the pixel size for points.
Philip Jennings
Technical Support Team Leader
Message 4 of 25
ncpapaul
It has been set as a default to "2" and will not accept any number, not even another "2".  I have to cancel to escape.  It asks me to enter a number between 0.001 and 10000.             But will not accept any value, just repeats that statement.  Same thing with the Wireframe value.   I'm confused and thanks for your help.
Message 5 of 25
AJHanson
Yes that is correct. When I click on options viewing "wireframe" is my defaulted window. Sorry I should have pointed that out.
Message 6 of 25
AJHanson
I've run into this too. It is asking dimension text size for "mm" i just inserted 20. I had to restart Program for it to take it thoughwireframe.png
Message 7 of 25
ncpapaul
It was somewhat connected to mm.   I had some random miniature value in mm in text size and after I put 4mm in there I can now enter any value in point size and it accepts it.  BUT it will not display a dot or point rather.  When I started I had points but super fine almost unseen.   I may be missing something simple right in front of me but it is frustrating.
Message 8 of 25
ncpapaul
Message 9 of 25
AJHanson
Give it a greater value. like 20 or 30 pixels I took a snap shot of my settings. See if that helps.
Message 10 of 25
ncpapaul
No change using 20 30 or 40 as a value.  And I am also quitting the program completely and restarting also just like someone suggested.
Message 11 of 25
ncpapaul
Now I can't even see any points of any size.
Message 12 of 25
Its a bug I think.  We ran into this.  Turn off or on (not sure what fixed it) use graphics hardware and restart FeatureCam.  It should work then
Message 13 of 25
abhishek.juvekar
Hi @ncpapaul,
To fix this problem follow the steps below ensuring the following setting is checked:
•Click on File to bring you to the backstage file menu
•Click on Options
•Click on and expand Display
•Click the Shaded option to bring up the Shaded options menu
•Make sure the Use graphics hardware box is checked. If unchecked, check it and restart FeatureCAM
•Now the point(s) should be visible.
We have reported this to FeatureCAM development team and they are aware of it.
Hope this helps.
If my post answers your query, please click on 'Accept as Solution' button.
Thank You.
Abhishek
Message 14 of 25
ncpapaul
My version is AutoDesk FeatureCam 2017 Ultimate. I do not see any of those options under "File" or "Options" . I attached a screen shot of what I see. What am I doing wrong? And thank you greatly. Paul
Message 15 of 25
phil.jenningsM7ZMZ
Hi Dakin,
 go to options,Viewing options and in the General tab you will see the point option you are looking for.
See attachment please.
Philip Jennings
Message 16 of 25
ncpapaul
But changing the values there does not make a point appear. No point appears at all, no matter the value.
Message 17 of 25
phil.jenningsM7ZMZ
Paul ,what kind of video card do you have?
 i know that some video cards do not play well with CAD/CAM graphics.
Philip Jennings
Message 18 of 25
ncpapaul
This is what is listed as my video card. I bought it in March this year. Thanks
PNY Quadro K620 VCQK620-PB 2GB 128-bit DDR3 PCI Express 2.0 x16 Plug-in Card Workstation Video Card
Message 19 of 25
ncpapaul
Message 20 of 25
phil.jenningsM7ZMZ
All right, lets try this.
open up the Nvidea control panel.
Select adjust image setting.
pick the third option and set it to performance. Select Apply ( See pdf Nvidea1. )
Next select the Set PhysX Config.
Change from auto-select to the Nvidea card. Select Apply. ( See Nvidea2 )
Philip Jennings
