I want change the hole type (for example from simply hole to tap hole),
but if I found a IFMPointListPattern instead of an IFMHole, how can I get the Feature in the list ?
private void CompareCSVlinesFeatures()
foreach (FMSetup setup in doc.Setups)
if (setup.Enabled == true)
setup.Activate();
foreach (FMFeature feature in setup.Features)
if (feature.Enabled == true)
if (feature is IFMHole)
//MessageBox.Show("Feature hole found: " + feature.Name); // Hole is found, all okay
else if (feature is IFMPointListPattern)
// IFMPointListPattern ######## How can I get the Feature of it, to change the type ???
Best regards
Maurizio Manzi
