API - C# - HoleRecognitionCylinders
maurizio_manzi
maurizio_manzi
does someone have an example for using HoleRecognitionCylinders() in a C# project ?
In VBA works fine:
Dim myModels As FMModels
Set myModels = doc.surfaces.HoleRecognitionCylinders(false, true)
But in C# I get an error message (...HoleRecognitionCylinders can't be used as a method...) for this code:
FMModels myModels
And next, in VBA I check if surface is a cylinder:
Dim myModel as FMModel
For Each myModel in myModels
If( TypeName(surf) = "IFMSurfaceCylinder") Then
But in C# we have not TypeName()
Best regards
Maurizio Manzi
Auron GmbH
craig.shipley
Autodesk Support
Autodesk Support
For the purpose of the forum post (for other interested people):
The solution(s) here:
  1. We must use [ ] istead of ( ), because . HoleRecognitionCylinders is not a method, it is a collection, so correct is:
Private void RecognizeCylinders()
  Foreach (FMSetup setup in doc.setups
    Foreach(FMModel model in doc.surfaces.HoleRecognitionCylinders[false, true, 999888777] // <<<<<< *** with [ ]  instead of ( ) ***
      //do something
And the second part....
If (surf is IFMSurfaceCylinder)
