FC - API - C# - How to get the Feature in the IFMPointListPattern
maurizio_manzi
maurizio_manzi
I want change the hole type (for example from simply hole to tap hole),
but if I found a IFMPointListPattern instead of an IFMHole, how can I get the Feature in the list ?
private void CompareCSVlinesFeatures()
          foreach (FMSetup setup in doc.Setups)
                  if (setup.Enabled == true)
                         setup.Activate();
                          foreach (FMFeature feature in setup.Features)
                                  if (feature.Enabled == true)
                                          if (feature is IFMHole)
                                                  //MessageBox.Show("Feature hole found: " + feature.Name); // Hole is found, all okay
                                  else if (feature is IFMPointListPattern)
                                          // IFMPointListPattern ######## How can I get the Feature of it, to change the type ???
Best regards
Maurizio Manzi
0 Me gusta
Responder
Soluciones aceptadas (1)
920 Vistas
3 Respuestas
Respuestas (3)
serge.quiblier
Solución aceptada
Hi @maurizio_manzi
Looking at the API help file:
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
nguyenthinhvt95
@serge.quiblier Do you have pdf file of this?
0 Me gusta
serge.quiblier
Hi @nguyenthinhvt95
I don't have a PDF version for the API.
If I found one on my computer, it will be a very old version pretty outdated.
The HTML online version can be accessed via
It can be downloaded locally, but it will still be a collection of html files.
Regards
Serge.Q
cam.autodesk.com
0 Me gusta
