Set some camera properties, not in FBX ASCII
ssontech
ssontech
I discovered a new flag I need to set in my commercial FBX exporter, I set it during export; read-back shows it has been set, but it still appears as false in the exported FBX ASCII file. I can do it either way below, no dice. It looks like a few other settings (LockMode, BackPlateScaleX/Y) may not be saved also. Using 2020.2.
lCam->SetBackPlateFitImage(true);
lCam->BackPlateFitImage.Set(true);
 The FbxCamera is created, various settings set, then it is added to an FbxNode. Eventually it gets exported, but always it results in
P: "BackPlateFitImage", "bool", "", "",0
The export is all long-time standard working stuff, I don't how setting this can't work.
ssontech
Similarly, I now need to be able to write data in a different rotation order, but see that FbxNode::RotationOrder isn't being written to the FBX either, it is always 0:
	P: "RotationOrder", "enum", "", "",0
The rotation angles I'm writing are all there, everything looks fine, but again a value isn't being written to the file. I'd really appreciate some explanation here on both of these. How can this not work? What kind of behind-the-scenes "logic" is at work?
