Creating a C++ Form Application Project with Autodesk API
Message 1 of 1
I have a very annoying problem. Let me describe it:
I want to create a C++ Form Project to display the structure and properties of .fbx files. To achieve this, I want to use Autodesk API to access the fbx file objects easily. I know creating a C++ Form Application Project is easy and also, I know when following the configurations in Autodesk website, it is easy to use fbxsdk API but when it comes to connect them in one project I constanly get the error:
Debug Assertion Failed!
Program:C:\Users\MyName\Desktop\FbxViewer\Debug\FbxViewer.exe
File:f:\dd\vctools\crt_bld\self_x86\src\dbgheap.c
Line:1516
Expression:_CrtlsValidHeappointer(pUserData)
Note that I get this error without using any fbxsdk API functions but only adding
 #include "fbxsdk.h"
after the header declarations in a default Form Application Project.
By the way, after creating Form Application Project, I set Common Language RunTime Support (/clr), Character Set to Use Multi-Byte Character Set, I add fbxsdk include to Additional Include Directories, Runtime Library to Multi-threaded Debug DLL (/MDd), I add
C:\Program Files\Autodesk\FBX\FBX SDK\2016.1.1\lib\vs2010\x86\debug
to Additional Library Directories in Linker->General and I choose
C:\Program Files\Autodesk\FBX\FBX SDK\2016.1.1\lib\vs2010\x86\debug\libfbxsdk-md.lib
as Additional Dependencies. When assertion window appears and then I click retry button I get:
FbxViewer.exe has triggered a breakpoint
Please, help me to handle this problem!
Replies (0)
